TwinTurbo.NET: Nissan 300ZX forum - Just a quick caveat, make sure the oil on the turbos isn't
SirpriZ
on May 22, 2015 at 9:31 PM
Re: Leaky valve seal symptoms should show up on decel. You
posted by Quick_Z
on May 22, 2015 at 08:58 PM
from an oil fitting (sure you already checked that). Leaky seals can leak into both the compressor and turbine side. You know, I'm not sure about the oil/debris reaching the plenum without leaving any residue in the pipes. Mark
Why is there oil in the plenum even after deleting pcv's?
Quick_Z
06:17:17 05/22/15
SirpriZ
15:28:26 05/22/15
Skimming isn't my strong suit. You said the outlet pipes
SirpriZ
16:21:44 05/22/15
Quick_Z
20:58:05 05/22/15
Just a quick caveat, make sure the oil on the turbos isn't -
SirpriZ
21:31:26 05/22/15
Stupid question
Goldchocobo
00:11:06 05/24/15
